CCleaner removes Java web start applications.
If you run a program via Java web start (Those .jnlp files mostly only used at sun's website :P) it stores itself under the Java temp dir in AppData but CCleaner deletes it from there also leaving the uninstall entry that such Apps leave not work properly forcing you to delete this entry using CCleaner uninstall manager or a similiar tool.
It might also destroy web start applications that create a desktop icon which is even worse.
