Hello
When i scan for registry issue the ccleaner scan find:
Missing startup Software C:\Program Files(x86)Windows Media Player\WMPNSCFG.exe HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Everytime i fix the issue it always comme back.
I did search a bit i do knw this is related whit media sharing...
But please advise if somebody do know how to fix this.
Thank you maxime
Does the file exist or is it missing? If the file does exist, then you can uncheck the box 'Run at startup'. Since you wont have that many uninstalls leaving behid a run key. My guess is that CC is having trouble reading the path possibly. So it dosent find the file.
Your running 64 bit version of Windows right? Vista, XP or 7?
Vista 64
Thank you for reply...
In startup section this exist yes but it need to run for WMP sharing media.
The thing is why ccleaner see it as a registry probleme...and after i fix it still coming back
Vista 64
Actuly the file was missing in Window Media Player folder.
I took it frm my other pc and add it to the missing folder one...
Look good so far run smouth no ccleaner registry problem so far...
Thank you
Happy you got that cleared up ![:D]()
