Ccleaner Pro
Hi Everyone,
This is probably a dumb question but I've been using Ccleaner Pro now for a number of years and just recently received a update. Now, however, in the app it says update to Ccleaner Pro when I thought that's what I've been running all these years. At the top of the app window it says in huge print Ccleaner Professional so I'm confused.
Thanks so much,
Paul W
Can you post a screenshot of it?
Or at least tell us is it version 6.18.10838?
Also if you go to Oprions>License key does it say that it's 'Active'? (Don't post a screenshot of your key here).
I saw a similar thing with the previous v6.18.10824 which was pulled and replaced.
This is what I saw at that time with v6.18.10824, it's Professional but for some reason Health Check didn't think that it was:
(Note that if you do somehow still have v6.18.10824 then it will probably at some point ask you to re-enter your licence to activate it; that's why it got pulled).
<a class="ipsAttachLink ipsAttachLink_image" data-extension="core_Attachment" data-fileext="JPG" data-fileid="18112" href="<fileStore.core_Attachment>/monthly_2023_11/Capture.JPG.dc9787bab13003aa9d5e4cc0a80ab785.JPG" rel=""><img alt="Capture.JPG" class="ipsImage ipsImage_thumbnailed" data-extension="core_Attachment" data-fileid="18112" data-ratio="69.50" data-unique="u4073nksp" width="1000" src="<fileStore.core_Attachment>/monthly_2023_11/Capture.thumb.JPG.b4d603032256dda8339eb867f2b38541.JPG"></a>
It was fixed with v618.10838.
