CCleaner Pro vs. Pro Plus
What is the difference for Android versions?
Quote
there are no "pro" or "pro plus" versions for android. there is either free or paid. the free version is completely useless.
you can pull up information about the "ccleaner" app for android at the "google play store."
the authentic "ccleaner" app is offered by "piriform."
https://play.google.com/store/apps/details?id=com.piriform.ccleaner
If you have purchased a CCleaner Pro Plus licence then that includes multi-device use on PC, Mac, and Android.
You can then use that licence key to 'Activate' CCleaner Android in the Google store, rather than purchasing CCleaner Android through Google Store.
The CCleaner Android that you get is exactly the same, the only difference is how you paid for it.
CCleaner Pro Plus purchased in july 2022 does NOT include android app
		<a href="https://play.google.com/store/apps/details?id=com.piriform.ccleaner" rel="external nofollow">https://play.google.com/store/apps/details?id=com.piriform.ccleaner</a>
you're mistaken. what the difference is, i don't know
17 minutes ago, rogerlmartin said:
There is a stand-alone CCleaner Professional for Android - which only covers Android and not PC or Mac. The "Pro Plus" you see there is not "Android Professional Plus" but CCleaner Professional Plus - 3 Device (for PC, Mac and Android). I am not sure where that $26.99 price comes from though, since 30% off the US$49.95 MSRP for CCleaner Professional Plus (https://support.ccleaner.com/s/article/what-is-the-subscription-renewal-price-for-ccleaner-professional) is $34.97. That's more like 46% off so presumably some limited-time offer (or marketing doing a price elasticity experiment).
As per my note on your other thread ...
... if you already have an active CCleaner Professional Plus licence that you purchased via the desktop route, you can always buy this one as well (the Plus, not the Pro for Android) and then ask customer support to "licence merge" to credit the time on your old licence to your new one.
