CCleaner Pro skiping cookies in MS Edge
I'm using CCleaner 5.39.6399 Pro on Win 10 Pro 1709 and it is skipping cleaning cookies in MS Edge. Is there any way to stop the cookies being skipped?
Usally this is caused by edge (or a program that uses webview) still running, perhaps in the background. Make sure all applications and apps are closed (check task manager's detailed processess window for edge, browser host, ms office and any running apps as all are known to lock the browser).
