Ccleaner Pro 6.03.10002 pops daily schedule/clean completed on desktop
WIn 11 Pro portable with CC Pro 6.03.10002 x64
Daily schedule is setup around 21:15 and it does run but pops up a message window every day to inform cleaning of files is completed.
In Smart Cleaning everything is set as "Automatically clean without notification" and browsers same on closing browser.
How can this annoying notice be turned off ? Especially annoying when in the middle of online class. This did not occur on earlier versions.
It's a setting in the new look scheduler,
You can change it for an already set schedule by editing the preferences, then on the next screen click Continue and you'll get the notification settings again, same as the screen above.
Those are set. Still being notified every day at 2111. How do I stop this?
13 hours ago, xClean said:
Well the obvious quick way is to turn off the scheduled cleaning and do it manually at a time that suits.
Of course that's not a fix.
Nobody else has mentioned this (yet) so I'll do some testing here with the scheduler.
I done some testing now.
It's working fine for me here, the notifications are obeying the settings like they should.
When they are turned off then at the scheduled time a flashing CCleaner icon appears breifly in the system tray (as it should do) but that's all.
So let's see if we can work out why it's acting differently for you and put it right.
Did you have that schedule set in the previous CCleaner versions?
I'm thinking that if that was the case then something may have got a bit scrambled when the scheduler was updated as part of the 6.03 update?
I'd try reinstalling CCleaner 6.03 over the top of your existing one.
You can get the installer here: <a href="https://www.ccleaner.com/ccleaner/builds" ipsnoembed="true" rel="external">https://www.ccleaner.com/ccleaner/builds</a>
Once downloaded just double click it to reinstall CCleaner.
If it's still not behaving after doing that then you could try uninstalling CCleaner and reinstalling from scratch.
(You might want to also do a Restart of your machine before reinstalling).
Make a note of your licence name and key before uninstalling, you'll need it to re-regiser the new install.
Version 6.04 Pro now installed and it still does the same thing on WIn11Pro and Win10Pro
Oddly enough it does NOT do this for cleaning browsers which are also set as Do not notify upon closing.
Have you tried uninstalling and reinstalling CCleaner?
