CCleaner Portable problem
Hi !
I'm testing CCleaner Portable (the version from Twisted Metal, but I've tested the other one too and the result is similar) and can't launch it.
When I try, I get this error message :
Registring: CCHelper.ocx Failed!
So I try by hand :
E:\Apps\CCleanerPortable>regsvr32 /s CCHelper.ocx
E:\Apps\CCleanerPortable>regsvr32 /s /u CCHelper.ocx
And no errors (but it give no error at all in all case, even with a wrong name...)
Can you point me where I'm wrong ?
try THIS :)
try THIS :)
Thanks, but sadly it doesn't help.
The dll are "registered" silently but ccleaner.exe won't run...
Well that is expected since the only difference between them is the name. :P
My guess would be that you don't have "install" privileges. Install privileges are needed for component registering. In XP home this means that you have to be an loggen on as administrator.
But if this is not the case, could you run the CCleaner portable in debug mode (Run the portable executable with /PDEBUG parameter or add DebugMode=1 under [PORTABLE] section in the INI file). This gives you more detailed errors in the debug log. :)
If you just get...
Registering CCleaner components...
Registering: CCHelper.ocx
The problem is the install privileges. :(
That looks like that...
I've tried the "normal" setup and it gave me an error at install...
