CCleaner options/users problem
In CCleaner for options and then choice users, CCleaner displays 10 users.
This is not right. Only 2 users (accounts) are known on the PC.
How do I fix this?
can you provide a screenshot?
what is your OS and CC version?
CC = V.5.33.6162 (64 bit)
OS = Windows 7 64-bit SP1
20170911120134179.pdf
so those 12 or so Users, do you see those in C:\Users\ ? (make sure you have Show hidden files, folders and drives unticked in Folder Options)
Hello,
In C:\Users I see only 2 users (openbaar and vvandijk) + a desktop.ini file. Folder Options show all hidden files and drives.
The 2 users are correct.
The list which is shown in CCleaner (10 users) is not correct!
Is there somebody who knows how to solve this problem?
Nobody knows??
Was this a clean install of Windows 7?
Did the machine belong to someone else before it was yours?
Do you share your internet connection with anyone else?
Do both users (openbaar and vvandijk) see the 10 users?
I could almost read some of the file you attached...
List the contents of c:\Users\
One way to do that (from command prompt):
dir /a c:\Users\
This PC/machine belong to former people before it became mine.
This was not a clean instal of Windows 7.
I did not share my internet connection with anyone else.
Both users (openbaar and vvandijk) see the 10 users!
dir /a c:\Users\ -------> gives:
<dir> default
<dir> public
<dir> vvandijk
desktop.ini
Problem is solved.
Solution: register-editor hkey_local_machine\software\microsoft\windowsNT\current version\profile list
S-1-5 (SID-codes)
check profile image paths
wrong users deleted by pressing DEL
Result: Problem solved!!
Good to hear you have sorted your problem :)
Thanks for posting what worked for you.
