Thanks, we'll look into this.
New version, issue not solved yet
Regards
Regards
Hi, are there any news about the issue reported here, which is still present in the last version?
It's pretty annoying and I am considering stop using CCleaner.
I know it's been sent to the devs.. :-)
Regards
Lst version same error.
After running CC cannot start download and need to reboot PC
regards
CCleaner "goes away" when Run cleaner pressed.
Unchecked "Sun Java" and it worked fine.
Windows 7 Ultimate 64-bit.
What do you mean, "goes away"?
By the way, I same same issue on 2 pC running Win 7 32 and 64 bit
Unchecking Java did not help..
It's not only downloading a software but also opening a Pdf file from the internet.
Only rebooting PC helps...
Is it really possible that this has not been fixed yet.
It has been there since Win 7 and IE8 came out.
Regards
..are there any news abouth this issue?
Is there a person from dev staff, that can spend 2 minutes to post here?
Regards
Hi,
We are still trying to come up with a solution for this, but we haven't been able to reproduce in house so it is hard to fix it.
Have you been able to narrow down which cleaning rule is possibly causing this issue? Is it "Temporary Internet Files"?
Thank you for your patience.
.. it seems so.
I have same issue on 2 pcs, 1 with Win7 32 and 1 with Win7 64 bit..
regards
Having exact same issue as OP in lastest version of ccleaner and Win 7 IE 8.. unfortunately will have to stop using ccleaner until it is fixed.
For some reason my 1st reply didn't get posted. I was having the same issue and was able to narrow it down to CCleaner trying to clean flash cookies. I de-selected Adobe Flash Player in the programs tab and everything is working like it should. If you want/need to delete flash cookies have a look here and it will show you how to do from the Adobe website.
This as been working for me for a couple of days now...
iKidd that's a good tutorial thanks.
Admins and Devs The above link does suggest downloading CCLeaner from an unofficial site "ninite.com" this site seems suspisious to me and moresoover is not (AFAIK) given permission to distribute CCLeaner, that said it looks like they are a download manager and may well be pulling the download from the Piriform site, I did think you should know though
New version same issue...
@ikidd,
""For some reason my 1st reply didn't get posted. I was having the same issue and was able to narrow it down to CCleaner trying to clean flash cookies. I de-selected Adobe Flash Player in the programs tab and everything is working like it should. If you want/need to delete flash cookies have a look here and it will show you how to do from the Adobe website.""
I did try it too, did not help..
Regards
Another version same issue..
Are you really looking into this+
I am NDA for Skype, we have tools that can get logs for everything Skype does when testing..
Do you have such tools too?
Is there any other in this forum experiencing that when CCleaner "cleans", and you try to download a software, then you cannot and PC needs a reboot to be able to download a software again?
Regards
