CCleaner older Versions - hopefully slim
Hello, are there any older versions availiable from CCleaner (slim)? I've got an old Embedded PC (without SSE functionality which maybe forces the error) that runs with v.5.25 (slim). Updating to 5.29 (slim) would not work. CCleaner fails to start. System is Windows XP 32bit.
If there is 5.25 (slim) i would like to go back to this, but for sure i would try 5.26 (slim), 5.27 (slim) and 5.28 (slim) for testing purposes.
Old Ccleaner builds are available on the right-hand side of this page
http://filehippo.com/download_ccleaner/
However they are not the slim builds.
I've found some of the versions at another "filehistory"-website, also the slim-ones. For your notice the version the old machine is able to run is 5.26.5937. After this there must be a codechange that prevents the old AMD-embedded-CPU from running ccleaner.
Even though the old versions on FileHippo aren't portable you can unpack them with 7-Zip or 7-Zip Portable which negates having to install them.
Old versions of CCleaner are also available at:
http://www.oldapps.com/ccleaner.php
http://www.oldversion.com/windows/ccleaner/
