Hi Nergal yep thats it !! I checked it again... here goes...
![:blink:]()
Hi Kalis,
Are we having fun or what ? I think so.
Man, Kalis, you must have a monster Recycle Bin(s) !!!
Or maybe that is part of the problem.
Tell us about your Recycle Bins. Also any messages that you get when you put stuff in there will help.
Just for your benefit and some other users as well. Do this fun thing before you print off your
CCleaner.ini file . After you see it, you may want to create a new backup of YOUR CCleaner.ini file also.
1. Start CCleaner.
2. This is the fun part. Just don't "goof it up" and not reset the option the way that it was when you started.
Toggle each "individual" option. If it is ticked then untick it and then tick it again . Vice-versa if it is unticked at the start.
3. Do this for each "individual" option in each category in each tab. Windows tab and Application tab.
4. Do this in Registry issues as well. Remember, "individual" options only.
5. Do this in Options > Settings This also includes the language.
6. Do this in Options > Advanced This also includes toggling the Save settings to INI file. This must be toggled last and left ticked but it must be toggled or this whole process is wasted.
7. Exit CCleaner.
Now look at the CCleaner.ini file. Nice and sorted and it shows each and every setting. We don't have to remember what the embedded internal "default" is.
When you provide a list then you can edit out personal info with XXX's and such. PLEASE DO SO.
davey
P.S. Here is an example of my CCleaner.ini file.
[Options]
Language=1033
UpdateKey=09/18/2008 06:10:16 AM
WINDOW_LEFT=0
WINDOW_TOP=34
WINDOW_WIDTH=852
WINDOW_HEIGHT=700
WINDOW_MAX=0
(App)*Config.msi Folder=True
(App)*MS Visual Studio 2005=True
(App)*MS Windows Wallpaper=True
(App)*MUICache=True
(App)*More Windows Explorer=True
(App)*Registry Mechanic=True
(App)*Windows Update Logs=True
(App)7-Zip=True
(App)ActiveX and Class Issues=True
(App)Adobe Flash Player=False
(App)Adobe Reader 8.0=True
(App)Application Paths=True
(App)Applications=True
(App)Autocomplete Form History=False
(App)Chkdsk File Fragments=True
(App)Clipboard=True
(App)Cookies=True
(App)Custom Folders=True
(App)Delete Index.dat files=True
(App)Desktop Shortcuts=False
(App)Empty Recycle Bin=False
(App)Fonts=True
(App)Foxit Reader=True
(App)Google Toolbar 4.0=True
(App)Grisoft AVG 7.0=True
(App)Help Files=True
(App)History=True
(App)Hotfix Uninstallers=False
(App)IIS Log Files=False
(App)Installer=True
(App)Invalid File Extensions=False
(App)Last Download Location=True
(App)MS Paint=True
(App)MS Wordpad=True
(App)MUI Cache=True
(App)Malwarebytes' Anti Malware=True
(App)Memory Dumps=True
(App)Menu Order Cache=False
(App)Missing Shared DLLs=True
(App)Obsolete Software=True
(App)Office 2003=True
(App)Office XP=True
(App)Old Prefetch data=False
(App)Other Explorer MRUs=True
(App)Paint Shop Pro 8.0=True
(App)Recent Documents=True
(App)Recently Typed URLs=True
(App)RegEdit=True
(App)Run (in Start Menu)=True
(App)Run At Startup=True
(App)Search Assistant Autocomplete=True
(App)Start Menu Ordering=True
(App)Start Menu Shortcuts=False
(App)Sun Java=True
(App)Temporary Files=True
(App)Temporary Internet Files=True
(App)Tray Notifications Cache=False
(App)User Assist History=False
(App)Window Size/Location Cache=False
(App)Windows Log Files=True
(App)Windows Media Player=True
(App)Windows Movie Maker=True
AutoClose=0
BackupDir=C:\Documents and Settings\XXXXX\My Documents
BackupPrompt=1
CookiesToSave=CCleaner.com|forum.piriform.com|grisoft.com|ie7pro.com|imagespeech
.com|karenware.com|kellys-korner-xp.com|mail.yahoo.com/dc|microsoft.com|piriform.com|recuva.com|search.technet.microsoft.com|support.mi
crosoft.com|technet.microsoft.com|update.microsoft.com|www.daniweb.com|www.karenw
are.com|www.microsoft.com|www.yahoo.com|yahoo.com|
CustomFiles=
CustomFolders=
DelayTemp=0
FFDetailed=0
HideWarnings=0
IEDetailed=1
MinimizeSystemTray=0
SecureDeleteType=0
UpdateCheck=0
