Think I had v5.30 running OK and did an update to 5.32 but it would not run properly just stuck as soon as started cleaning so tried going back to 5.30 but the installer would not run, just got blue circle for several mins then prog not responding.
Also tried portable version and it will not clean either, tried run as admin but no difference.
Don't seem to have any probs with any other software.
Running win 10 build 16232 x64
Build 16232 is an 'insider' build (ie. a beta version).
You won’t find any software that guarantees to run correctly on a beta version of an operating system.
That’s the trade off of being on the insider ring of Win10.
You get new updates early, but they are not fully tested and often break things.
That’s the whole idea, you are testing them for Microsoft to see what needs to be sorted out.
That’s just the way it is with beta/insider versions.
You should report any problems to Microsoft, it is their insider build changes that cause these problems and that is what they want insiders too tell them about.
