Hi, for some months now and through several different iterations of CCleaner I have had a problem. When I open CCleaner initialy, everything appears except the checkbox items, also CCleaner renders itself unusable by using the hourglass so nothing can be opened. This continues for between 1 to 2.5 minutes then the checkboxes appear along with the normal curser and everything is as normal. is it my PC or CCleaner?
Are you using a winapp2.ini or any ccleaner enhancing addons?
