vida
1
Hi
I've been using CCleaner for some time now but its just stopped working.
I can "Analyze" but when I "Run Cleaner" it just stops responding and I have to Ctl Alt Dlt to shut it down.
Ive uninstalled and reinstalled but same problem still exists.
Any ideas please?
Thanks
In what condition is your computer?
Are you aware of any spyware/adware/virus/trojans or other malware?
Try first run some anti-virus and anti-(ad/spy/mal)-ware and see if that fix it.
vida
3
Hi
I backup and clean my computer weekly.
I use Spybot, Adaware and Ewido along with Ccleaner and have Norton installed.
I already did run spyware checks, cleared out a few things but still the same problem even after I uninstalled and re-installed.
Any other ideas.
Thanks
Have you tried the new Beta release?
CCleaner v1.27 Beta
I just tried it and it works really well.
You may want to post a HijackThis log to check for any issues.
HijackThis Instructions
Hope this helps
PS- Welcome to the forum!
vida
5
Thanks for your help.
Just installed the new v.1.27 and seems to be working again fine now.
Cheers muchly ![:D]()
I'm glad things worked out well and appreciate you letting me know
Thanks!
