Hi,
Just to report that the latest CCleaner is not emptying the Recycle Bin (Win 8.1, CCleaner v4.17.4804 (64 bit).
Regards,
Tony
Hi,
Regards,
Tony
obvious question I know, but have you ticked the box to Empty Recycle Bin.
and have you unticked the 2 Only delete files.....24 hours options in Options/Advanced?
(maybe a typo, but the latest version is .4808)
Sames issue checked to empty trash and unticked 24hr i also noticed this issue on a dell venue pro 8 8.1
In both cases trash is acctually empty it seems to be falsely reporting it is not.....
Sounds like you are describing a long time Windows bug where, even though the recycle bin empties the icon remains the "Full Icon"
Can you confirm, as well can the original poster reply if this is the case with you, else @ghamden will need to start a new thread.
No it only shows in CCleaner that file haven't been deleted.
I think the issue has to do with One Drive the filles that it shows as undleted were acctually deleted from One Drive and are here is a log file of what it did some items weren't run because browser is open
Details of files deleted
Windows Explorer - Thumbnail Cache 2,055 KB 12 files
System - Empty Recycle Bin 72,392 KB 12 files
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$R7SDIYD.QDF-backup 6,012 KB
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$RFMOVPJ.QDF-backup 6,048 KB
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$RGILQOM.QDF-backup 6,052 KB
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$RGZLT2C.QDF-backup 6,032 KB
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$RPUDZ16.QDF-backup 6,012 KB
C:$Recycle.Bin\S-1-5-21-2862259019-717915881-1823655684-1001$RYYHVZU.QDF-backup 6,040 KB
Those in list don't exist i can't find them .
but it occured after quicken backup files were deleted from one drive.
