CCleaner not delete all Remote Desktop settings
Hello to ALL.
I have use that great software CCcleaner 4.08.4428
There is problem with Remote Desktop Connection settings
The keys from HKEY_USERS\Any_User_ID\Software\Microsoft\Terminal Server Client\Servers
or
The keys from HKEY_CURRENT_USER\Software\Microsoft\Terminal Server Client\Servers
Are not deleted.
Please make them to delete.
Other bug:
if you open Remote Desktop Connection after clean the last server appears.
As workaround i manualy delete the last server and press save.
After close and open again there is not server any more.
Please repair that too.
Thanks at advance.
Hello.
There is any news about that bugs?
Are they will be fixed?
I am not going to rush noone, i just want to know that i was listen, because noone replay to my post.
Thanks.
Is the issue resolved in v4.09 (Released today?)
dima9751,
Have you considered using a custom "winapp2.ini" file for your specific needs?
Copy the following code into Notepad and save as "winapp2.ini" (using quotes) in the same directory as you have CCleaner.
[Remote Desktop]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Terminal Server Client
Default=True
FileKey1=%localappdata%\Microsoft\Terminal Server Client\Cache|*.*
RegKey1=HKCU\Software\Microsoft\Terminal Server Client\Default
Open up CCleaner and look for the new "Remote Desktop" checkbox under the "Windows" category.
