ccleaner never finishes cleaning
Thanks in advance for the help fellow members. I have Win 7 and when I run ccleaner it just stays on IE temp files and never gets out. If I uncheck temp files, it runs normally. It is IE 11. Anyone have this issue and fix it?
one scenario, if you have never ran CC (or done maintenance in general) before and have been using IE for years, there simply could be just so much junk it needs to cleanup.
how long have you left it for?
I have occasionally had to wait for maybe 15-20mins on some PC's.
2 things to try; either do an initially CC from Safe Mode, or go into IE and do a delete Browsing History and tick the areas you want covered.
