Ccleaner ne répond pas
Bonjour j’ai trop souvent l’erreur Ccleaner ne répond pas et donc je ne peux pas naviguer sur Internet En connaissez-vous les raisons ? D’avance Merci pour vos réponses
CCleaner not responding would not prevent you from using the internet.
Could you explain more just what you mean?
Le message d’erreur est ‘‘Ccleaner ne répond pas’’ et là je suis bloqué ça mouline ça mouline je ne peux plus aller sur Internet
Even if CCleaner is stuck ‘not responding’ like that you should still be able to open a browser and access the internet.
Being honest I suspect that it is your Internet Connection that is faulty so your browser(s) can’t connect, - and neither can CCleaner or anything else that need to use the internet.
Are you posting this from a different device? One connected to a different Internet Connection?
(Maybe from your smart phone? or a tablet with a SIM card?).
If/when CCleaner gets stuck then you can often close it using the ‘X’ in the top right corner (Just like any other app).
If you have trouble with doing that then open Windows Task Manager and ‘End Task’ on CCleaner.
Lets see if we can find why it is sticking for you.
What were/are you doing that caused/causes CCleaner to get stuck?
Is it when you are Opening CCleaner? Or updating Software? or Drivers? Or doing something else?
merci beaucoup pour vos conseils
