The last tow or three versions of CCleaner skip Edge during Custom Clean. As I refuse to run Edge for any reason I don't know why CCleaner keeps skipping it. Any ideas?
It will be skipping it because Edge is running in the background.
(Yes it will do that even if you never use it).
See this for how to stop it (and other Windows apps) doing that:
