CCleaner gets stuck in IE History cleaning
Hey guys, pretty weird problem I'm currently experiencing, just today my CCleaner gets stuck when cleaning/going over the IE History check, the weird thing is, it worked perfectly fine yesterday, what could be causing this?
Info:
Using the latest build of CCleaner
Using CCEnhancer as well
Running Windows 8 Pro.
Sorry SlackerITGuy but we don't support CCEnhancer on this forum so are unable to help with this issue. :(
But IE History cleaning is not one of CCEnhancer's enhanments lol, it comes built in CCleaner itself.
I'm pretty sure this is not related to CCEnhancer since it has been reported before: http://forum.piriform.com/index.php?showtopic=31596
that maybe true, however to receive aid you must first remove enhancer and then make your report if the "bug" persists, them's the rules.
to boot, the example you noted is a different issue (from 2011, ie 9 pre-release, windows7 and only slightly relates at all only because it mentions ie history). Please run debug (instructions on sticky at the top of this hoard), crash your ccleaner with task manager and post the log to this thread as an attachment (or in code tags)
