System specs:
Windows 8.1 64bit
AMD FX-6200 Zambezi 6-Core 3.8GHz
Memory 10 GB Speed: PC3-12800 MB/s Type: DDR3-1600
CCleaner started acting up. It now triggers UAC, which it didn't before. I can start the program and 1 of 2 things will happen. 1) it will open and when I mouse over it, I get the busy signal from the cursor. 2) it will just sit there and can't click on anything. Frozen.
I had some of this go on with the last version too. The only way to stop the program is through Task Manager.
I've uninstalled/reinstalled rather than update. No change. File I downloaded was from Piriform.
