CCleaner freezes while cleaning
Hi,
CCleaner has started to freeze while cleaning. It gets to 28% and seems to be stuck on this file.. C:\Windows\setupapi.log
To confirm that's the problem, try running CCleaner once with Windows Log Files deselected and then with only Windows Log Files selected, or try deleting C:\Windows\setupapi.log once manually and see if CCleaner will run afterwards.
