CCleaner for MAC OS 15.2 will not launch after clean install
Dear CCleaner,
I am reaching out regarding an issue I am encountering with CCleaner on my macOS 15.2 system. After installing the latest version of CCleaner, I am unable to launch the application. Specifically, the software installs without error, but when I attempt to run it, the application fails to open, and there is no error message or further indication of what might be causing the issue.
To troubleshoot, I have already attempted the following steps:
  1. Uninstalled and Reinstalled: I performed a full uninstallation of CCleaner, followed by a clean reinstallation using the latest version from your website. Despite this, the application still fails to launch.
  2. Checked Permissions and Security Settings: I have verified that macOS security and privacy settings allow applications from identified developers to run, and I ensured no firewall or third-party security software could be blocking the application.
  3. Attempted System Reboot: I restarted the system after installation, as well as after clearing system caches, in case of any residual issues, but the issue persists.
Given these steps, I am looking for additional insights or troubleshooting suggestions that may resolve this issue. It seems there may be a compatibility or configuration conflict specific to macOS 15.2, or potentially an underlying problem with how the application interfaces with the operating system’s security and permissions architecture.
I would greatly appreciate your assistance in addressing this issue. Please let me know if you require any further details, such as system logs or error reports, to aid in diagnosing the problem.
Thank you in advance for your support.
Best regards,
Greg
I got it installed and it launches, but the Overview section displays inaccurate results. For example, regardless of how many cookies have been added to the system, it always displays 24 cookies and 524 KB. (To be safe, I manually delete them through Safari’s settings.) CCleaner appears to delete App and Web Cache files. Also, it never sees any files in the Trash.
I have same probleam
after I remove it and try to re-install
the app fail to open without any error or message , when I click it no things happen
below is the log from console
default	21:57:25.413161+0300	lsd	com.piriform.ccleaner/Unknown Persona:5:5:1:1:Building bundle record for app
default	21:57:25.413281+0300	lsd	com.piriform.ccleaner/Unknown Persona:5:5:2:1:Built bundle record for app
default	21:57:25.419563+0300	lsd	com.piriform.ccleaner/Unknown Persona:5:4:2:1:_LSServerRegisterItemInfo result = 0
default	21:57:25.421147+0300	dmd	Received xpc stream event (distributed notification matching) with name: com.apple.LaunchServices.applicationRegistered user info: {
    bundleIDs =     (
        "com.piriform.ccleaner"
    isPlaceholder = 0;
default	21:57:25.422799+0300	runningboardd	Launch request for app<application.com.piriform.ccleaner.86958804.86958809(501)>[0] is using uid 501 (divined from auid 501 euid 501)
default	21:57:25.422858+0300	runningboardd	Acquiring assertion targeting app<application.com.piriform.ccleaner.86958804.86958809(501)> from originator [osservice<com.apple.coreservices.uiagent(501)>:578] with description <RBSAssertionDescriptor| "LS launch com.piriform.ccleaner" ID:378-578-779 target:app<application.com.piriform.ccleaner.86958804.86958809(501)> attributes:[
	<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"LaunchRoleUserInteractive" sourceEnvironment:"(null)">
default	21:57:25.422924+0300	runningboardd	Assertion 378-578-779 (target:app<application.com.piriform.ccleaner.86958804.86958809(501)>) will be created as active
default	21:57:25.430109+0300	runningboardd	Executing launch request for app<application.com.piriform.ccleaner.86958804.86958809(501)> (LS launch com.piriform.ccleaner)
default	21:57:25.430128+0300	runningboardd	Checking PreventLaunch: global:0 exPath:/Applications/CCleaner.app/Contents/MacOS/CCleaner predicates:(null) allow:(null)
default	21:57:25.430155+0300	runningboardd	Creating and launching job for: app<application.com.piriform.ccleaner.86958804.86958809(501)>
default	21:57:25.430171+0300	runningboardd	_mutateContextIfNeeded called for com.piriform.ccleaner
default	21:57:25.430296+0300	runningboardd	app<application.com.piriform.ccleaner.86958804.86958809(501)>: -[RBPersonaManager personaForIdentity:context:personaUID:personaUniqueString:] required 0.000000 ms (wallclock); resolved to {4294967295, (null)}
default	21:57:25.430392+0300	runningboardd	'app<application.com.piriform.ccleaner.86958804.86958809(501)>' Constructed job description:
<dictionary: 0xbdccad0e0> { count = 23, transaction: 0, voucher = 0x0, contents =
	"Platform" => <int64: 0xab01153aa745de97>: 1
	"ProcessType" => <string: 0xbdccd3d80> { length = 3, contents = "App" }
	"EnableTransactions" => <bool: 0x2060b92e0>: false
	"_ManagedBy" => <string: 0xbdccd18c0> { length = 22, contents = "com.apple.runningboard" }
	"CFBundleIdentifier" => <string: 0xbdccd3bd0> { length = 21, contents = "com.piriform.ccleaner" }
	"_ResourceCoalition" => <string: 0xbdccd35a0> { length = 61, contents = "app<application.com.piriform.ccleaner.86958804.86958809(501)>" }
	"_DisablePointerAuth" => <bool: 0x2060b92c0>: true
	"ThrottleInterval" => <int64: 0xab01153958ba2167>: 2147483647
	"MachServices" => <dictionary: 0xbdccad380> { count = 0, transaction: 0, voucher = 0x0, contents =
	"EnablePressuredExit" => <bool: 0x2060b92e0>: false
	"LimitLoadToSessionType" => <array: 0xbdccd3e10> { count = 2, capacity = 8, contents =
		0: <string: 0xbdccd27c0> { length = 4, contents = "Aqua" }
		1: <string: 0xbdccd1080> { length = 11, contents = "LoginWindow" }
	"InitialTaskRole" => <int64: 0xab01153aa745de8f>: 2
	"EnvironmentVariables" => <dictionary: 0xbdccac480> { count = 14, transaction: 0, voucher = 0x0, contents =
		"__CF_USER_TEXT_ENCODING" => <string: 0xbdccd38a0> { length = 13, contents = "0x1F5:0x0:0x0" }
		"LaunchInstanceID" => <string: 0xbdccd07e0> { length = 36, contents = "82ACD5CC-52CB-4518-B4D0-200473229D5E" }
		"TMPDIR" => <string: 0xbdccd3c60> { length = 49, contents = "/var/folders/22/xsjw_wm90kz84h2sd3h4jklw0000gn/T/" }
		"SHELL" => <string: 0xbdccd3c30> { length = 8, contents = "/bin/zsh" }
		"HOME" => <string: 0xbdccd0f30> { length = 15, contents = "/Users/aliammar" }
		"SSH_AUTH_SOCK" => <string: 0xbdccd3ba0> { length = 51, contents = "/private/tmp/com.apple.launchd.wJSyoROUAw/Listeners" }
		"LOGNAME" => <string: 0xbdccd2760> { length = 8, contents = "aliammar" }
		"PATH" => <string: 0xbdccd3cc0> { length = 44, contents = "/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin" }
		"XPC_SERVICE_NAME" => <string: 0xbdccd3db0> { length = 47, contents = "application.com.raycast.macos.82384940.84896115" }
		"__CFBundleIdentifier" => <string: 0xbdccd3cf0> { length = 21, contents = "com.piriform.ccleaner" }
		"COMMAND_MODE" => <string: 0xbdccd01b0> { length = 8, contents = "unix2003" }
		"SECURITYSESSIONID" => <string: 0xbdccd3c00> { length = 5, contents = "186b2" }
		"USER" => <string: 0xbdccd3de0> { length = 8, contents = "aliammar" }
		"XPC_FLAGS" => <string: 0xbdccd0ed0> { length = 3, contents = "0x0" }
	"_AdditionalProperties" => <dictionary: 0xbdccad1a0> { count = 1, transaction: 0, voucher = 0x0, contents =
		"RunningBoard" => <dictionary: 0xbdccacae0> { count = 4, transaction: 0, voucher = 0x0, contents =
			"TMPDIR" => <string: 0xbdccd3c90> { length = 49, contents = "/var/folders/22/xsjw_wm90kz84h2sd3h4jklw0000gn/T/" }
			"HOME" => <string: 0xbdccd0e40> { length = 15, contents = "/Users/aliammar" }
			"RunningBoardLaunchedIdentity" => <dictionary: 0xbdccacc00> { count = 5, transaction: 0, voucher = 0x0, contents =
				"AJL" => <string: 0xbdccd3b70> { length = 51, contents = "application.com.piriform.ccleaner.86958804.86958809" }
				"TYPE" => <int64: 0xab01153aa745de97>: 1
				"AUID" => <uint64: 0xab81153aa745d137>: 501
				"EAI" => <string: 0xbdccd0ab0> { length = 21, contents = "com.piriform.ccleaner" }
				"PLAT" => <uint64: 0xab81153aa745de97>: 1
			"RunningBoardLaunched" => <bool: 0x2060b92c0>: true
	"ExitTimeOut" => <int64: 0xab01153aa745de97>: 1
	"Label" => <string: 0xbdccd3d50> { length = 51, contents = "application.com.piriform.ccleaner.86958804.86958809" }
	"WaitForDebugger" => <bool: 0x2060b92c0>: true
	"MaterializeDatalessFiles" => <bool: 0x2060b92c0>: true
	"WorkingDirectory" => <string: 0xbdccd08d0> { length = 1, contents = "/" }
	"_LaunchType" => <int64: 0xab01153aa745de87>: 3
	"AbandonProcessGroup" => <bool: 0x2060b92c0>: true
	"ProgramArguments" => <array: 0xbdccd0ba0> { count = 1, capacity = 8, contents =
		0: <string: 0xbdccd3090> { length = 50, contents = "/Applications/CCleaner.app/Contents/MacOS/CCleaner" }
	"Program" => <string: 0xbdccd3d20> { length = 50, contents = "/Applications/CCleaner.app/Contents/MacOS/CCleaner" }
default	21:57:25.437609+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] is not RunningBoard jetsam managed.
default	21:57:25.437624+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] This process will not be managed.
default	21:57:25.437634+0300	runningboardd	Now tracking process: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.437781+0300	runningboardd	Calculated state for app<application.com.piriform.ccleaner.86958804.86958809(501)>: running-active (role: UserInteractive) (endowments: <private>)
default	21:57:25.438652+0300	gamepolicyd	Hit the server for a process handle 16c4bcec000005e3 that resolved to: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.438685+0300	gamepolicyd	Received state update for 1507 (app<application.com.piriform.ccleaner.86958804.86958809(501)>, running-active-NotVisible
default	21:57:25.443355+0300	runningboardd	Using default underlying assertion for app: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.443408+0300	runningboardd	Acquiring assertion targeting [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] from originator [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] with description <RBSAssertionDescriptor| "RB Underlying Assertion" ID:378-378-780 target:1507 attributes:[
	<RBSDomainAttribute| domain:"com.apple.underlying" name:"defaultUnderlyingAppAssertion" sourceEnvironment:"(null)">,
	<RBSAcquisitionCompletionAttribute| policy:AfterApplication>
default	21:57:25.443469+0300	runningboardd	Assertion 378-378-780 (target:[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]) will be created as active
default	21:57:25.443649+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring jetsam update because this process is not memory-managed
default	21:57:25.443679+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring suspend because this process is not lifecycle managed
default	21:57:25.443701+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Set darwin role to: UserInteractive
default	21:57:25.443766+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring GPU update because this process is not GPU managed
default	21:57:25.443867+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] reported to RB as running
default	21:57:25.443905+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring memory limit update because this process is not memory-managed
default	21:57:25.444912+0300	runningboardd	Acquiring assertion targeting [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] from originator [osservice<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "uielement:1507" ID:378-345-781 target:1507 attributes:[
	<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"RoleUserInteractive" sourceEnvironment:"(null)">
default	21:57:25.444648+0300	CoreServicesUIAgent	LAUNCH: 0x0-0x55055 com.piriform.ccleaner starting stopped process.
default	21:57:25.445063+0300	runningboardd	Assertion 378-345-781 (target:[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]) will be created as active
default	21:57:25.445693+0300	loginwindow	-[ApplicationManager checkInAppContext:eventData:] | ApplicationManager: Checked in app : CCleaner
default	21:57:25.448622+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring jetsam update because this process is not memory-managed
default	21:57:25.448666+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring suspend because this process is not lifecycle managed
default	21:57:25.448709+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring GPU update because this process is not GPU managed
default	21:57:25.448796+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring memory limit update because this process is not memory-managed
default	21:57:25.448910+0300	runningboardd	Successfully acquired underlying assertion for [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.455177+0300	runningboardd	Calculated state for app<application.com.piriform.ccleaner.86958804.86958809(501)>: running-active (role: UserInteractive) (endowments: <private>)
default	21:57:25.455594+0300	gamepolicyd	Received state update for 1507 (app<application.com.piriform.ccleaner.86958804.86958809(501)>, running-active-NotVisible
default	21:57:25.455728+0300	runningboardd	Invalidating assertion 378-578-779 (target:app<application.com.piriform.ccleaner.86958804.86958809(501)>) from originator [osservice<com.apple.coreservices.uiagent(501)>:578]
default	21:57:25.455780+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring jetsam update because this process is not memory-managed
default	21:57:25.455928+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring suspend because this process is not lifecycle managed
default	21:57:25.456002+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring GPU update because this process is not GPU managed
default	21:57:25.456135+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] Ignoring memory limit update because this process is not memory-managed
default	21:57:25.461754+0300	runningboardd	Calculated state for app<application.com.piriform.ccleaner.86958804.86958809(501)>: running-active (role: UserInteractive) (endowments: <private>)
default	21:57:25.465867+0300	CCleaner	[0x600000d80000] activating connection: mach=true listener=false peer=false name=com.apple.cfprefsd.daemon
default	21:57:25.465950+0300	CCleaner	[0x600000d800f0] activating connection: mach=true listener=false peer=false name=com.apple.cfprefsd.agent
default	21:57:25.468436+0300	CCleaner	[0x600000d88000] activating connection: mach=true listener=false peer=false name=com.apple.coreservices.launchservicesd
default	21:57:25.468935+0300	CCleaner	[0x600000d940f0] activating connection: mach=true listener=false peer=false name=com.apple.analyticsd
default	21:57:25.469243+0300	CCleaner	[0x600000d880f0] activating connection: mach=true listener=false peer=false name=com.apple.pasteboard.1
default	21:57:25.469700+0300	CCleaner	Received configuration update from daemon (initial)
default	21:57:25.469755+0300	CCleaner	[0x600000d8c000] activating connection: mach=true listener=false peer=false name=com.apple.distributed_notifications@Uv3
default	21:57:25.472836+0300	CCleaner	void _NSDisableAutomaticTerminationAndLog(NSString *) No windows open yet
default	21:57:25.473443+0300	CCleaner	[0x600000d801e0] activating connection: mach=true listener=false peer=false name=com.apple.tccd.system
default	21:57:25.474128+0300	tccd	AUTHREQ_ATTRIBUTION: msgID=1507.1, attribution={requesting={TCCDProcess: identifier=com.piriform.ccleaner, pid=1507, auid=501, euid=501, binary_path=/Applications/CCleaner.app/Contents/MacOS/CCleaner}, },
default	21:57:25.475884+0300	tccd	AUTHREQ_SUBJECT: msgID=1507.1, subject=com.piriform.ccleaner,
default	21:57:25.476706+0300	tccd	-[TCCDAccessIdentity staticCode]: static code for: identifier com.piriform.ccleaner, type: 0: 0xb2c2e2d00 at /Applications/CCleaner.app
default	21:57:25.479801+0300	CCleaner	[0x600000d801e0] invalidated after the last release of the connection object
default	21:57:25.479973+0300	CCleaner	server port 0x00003007, session port 0x00003007
default	21:57:25.480916+0300	tccd	AUTHREQ_ATTRIBUTION: msgID=372.155, attribution={accessing={TCCDProcess: identifier=com.piriform.ccleaner, pid=1507, auid=501, euid=501, binary_path=/Applications/CCleaner.app/Contents/MacOS/CCleaner}, requesting={TCCDProcess: identifier=com.apple.WindowServer, pid=372, auid=88, euid=88, binary_path=/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer}, },
default	21:57:25.480962+0300	tccd	requestor: TCCDProcess: identifier=com.apple.WindowServer, pid=372, auid=88, euid=88, binary_path=/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer is checking access for accessor TCCDProcess: identifier=com.piriform.ccleaner, pid=1507, auid=501, euid=501, binary_path=/Applications/CCleaner.app/Contents/MacOS/CCleaner
default	21:57:25.482213+0300	tccd	AUTHREQ_SUBJECT: msgID=372.155, subject=com.piriform.ccleaner,
default	21:57:25.483319+0300	tccd	-[TCCDAccessIdentity staticCode]: static code for: identifier com.piriform.ccleaner, type: 0: 0xb2c2e2d00 at /Applications/CCleaner.app
default	21:57:25.490195+0300	CCleaner	New connection 0x8af23 main
default	21:57:25.492487+0300	CCleaner	CHECKIN: pid=1507
default	21:57:25.496361+0300	launchservicesd	CHECKIN:0x0-0x55055 1507 com.piriform.ccleaner
default	21:57:25.496438+0300	CCleaner	CHECKEDIN: pid=1507 asn=0x0-0x55055 foreground=0
default	21:57:25.496690+0300	loginwindow	-[ApplicationManager checkInAppContext:eventData:] | ApplicationManager: Checked in app : CCleaner
default	21:57:25.496507+0300	runningboardd	Acquiring assertion targeting [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] from originator [osservice<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "uielement:1507" ID:378-345-782 target:1507 attributes:[
default	21:57:25.496560+0300	runningboardd	Assertion 378-345-782 (target:[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]) will be created as active
default	21:57:25.496582+0300	CCleaner	[0x14e504080] activating connection: mach=false listener=true peer=false name=(anonymous)
default	21:57:25.496591+0300	CCleaner	[0x14e504080] Channel could not return listener port.
default	21:57:25.496696+0300	CCleaner	[0x12ce04080] activating connection: mach=false listener=false peer=true name=com.apple.xpc.anonymous.0x14e504080.peer[345].0x12ce04080
default	21:57:25.497081+0300	runningboardd	Invalidating assertion 378-345-781 (target:[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]) from originator [osservice<com.apple.coreservices.launchservicesd>:345]
default	21:57:25.498475+0300	CCleaner	FRONTLOGGING: version 1
default	21:57:25.498567+0300	CCleaner	Registered, pid=1507 ASN=0x0,0x55055
default	21:57:25.499219+0300	CCleaner	[0x14e405890] activating connection: mach=true listener=false peer=false name=com.apple.lsd.mapdb
default	21:57:25.499799+0300	CCleaner	[0x14e504080] Channel could not return listener port.
default	21:57:25.500837+0300	CCleaner	BringForward: pid=1507 asn=0x0-0x55055 bringForward=0 foreground=0 uiElement=1 launchedByLS=1 modifiersCount=1 allDisabled=0
default	21:57:25.501121+0300	CCleaner	BringFrontModifier: pid=1507 asn=0x0-0x55055 Modifier 0 hideAfter=0 hideOthers=0 dontMakeFrontmost=0 mouseDown=0/0 seed=0/0
default	21:57:25.501633+0300	CCleaner	Current system appearance, (HLTB: 2), (SLS: 1)
default	21:57:25.503890+0300	CCleaner	Current system appearance, (HLTB: 2), (SLS: 1)
default	21:57:25.504302+0300	CCleaner	Post-registration system appearance: (HLTB: 2)
default	21:57:25.512578+0300	CCleaner	[0x14e504080] Channel could not return listener port.
default	21:57:25.513199+0300	distnoted	register name: com.apple.xctest.FakeForceTouchDevice object: com.piriform.ccleaner token: 1e00000021 pid: 1507
default	21:57:25.516235+0300	CCleaner	[0x14e504080] Channel could not return listener port.
default	21:57:25.518825+0300	CCleaner	Entering exit handler.
default	21:57:25.518832+0300	CCleaner	Queueing exit procedure onto XPC queue. Any further messages sent will be discarded. activeSendTransactions=0
default	21:57:25.518914+0300	CCleaner	Cancelling XPC connection. Any further reply handler invocations will not retry messages
default	21:57:25.518944+0300	CCleaner	[0x600000d940f0] invalidated because the current process cancelled the connection by calling xpc_connection_cancel()
default	21:57:25.518982+0300	CCleaner	Exiting exit handler.
default	21:57:25.518990+0300	CCleaner	XPC connection invalidated (daemon unloaded/disabled)
default	21:57:25.519773+0300	runningboardd	[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507] termination reported by launchd (0, 0, 256)
default	21:57:25.519798+0300	runningboardd	Removing process: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.519989+0300	runningboardd	Removing launch job for: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.520148+0300	runningboardd	Removed job for [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.520168+0300	runningboardd	Removing assertions for terminated process: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.529863+0300	runningboardd	Calculated state for app<application.com.piriform.ccleaner.86958804.86958809(501)>: none (role: None) (endowments: (null))
default	21:57:25.529972+0300	runningboardd	Calculated state for app<application.com.piriform.ccleaner.86958804.86958809(501)>: none (role: None) (endowments: (null))
default	21:57:25.530453+0300	launchservicesd	Hit the server for a process handle 16c4bcec000005e3 that resolved to: [app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507]
default	21:57:25.530649+0300	gamepolicyd	Received state update for 1507 (app<application.com.piriform.ccleaner.86958804.86958809(501)>, none-NotVisible
default	21:57:25.531711+0300	loginwindow	-[PersistentAppsSupport applicationQuit:] | for app:CCleaner, _appTrackingState = 2
error	21:57:25.559007+0300	runningboardd	RBSStateCapture remove item called for untracked item 378-345-781 (target:[app<application.com.piriform.ccleaner.86958804.86958809(501)>:1507])
error	21:57:25.559029+0300	runningboardd	RBSStateCapture remove item called for untracked item 378-578-779 (target:app<application.com.piriform.ccleaner.86958804.86958809(501)>)
Let me fire up my mac and do some testing real quick.
Has anyone resolved this issue? I just installed CCleaner for Mac on my macbook, and everything went fine with the installer, but the app will NOT launch.
No it has not been fixed, it was never resolved. I gave up waiting for a reply from CCleaner and went with another app. (CleanMyMac) works great and is much more thorough and does a better job on a Mac than CCleaner.
Thanks. I also got CleanMyMac and am happy with it however it doesn’t have all the features that CCleaner has - including managing startup options. Oh well, guess CCleaner doesn’t care to retain customers.
CCleaner’s main customer is the Windows user. You’re right they don’t seem to care to retain their customers. That’s why the MAC was just an after thought for them. Under the performance tab in CleanMyMac you can manage your start up options, you can remove but I don’t believe you can add an item. That would have to be done in the MAC’s systems preferences.
Same here!
