CCleaner.exe Problems
Hi guys !
I don't know why the system always show the alert window about the application
here is the problem
I have try to reinstall the software many times but it's still in the same problem,
Can you say which operating system you are using and which 'bitness'
Have you had ccleaner installed before?
Are you installing it to the default place that it suggests when it installs?
Have a quick read here also
http://forum.piriform.com/index.php?showtopic=5739
Can you say which operating system you are using and which 'bitness' Windows 7 32-bit
Have you had ccleaner installed before? Yes
Are you installing it to the default place that it suggests when it installs? Yes, in C:\Program Files\CCleaner\
http://forum.pirifor...?showtopic=5739 Very helpful but not the one I looking for -_-
Is CCleaner.exe actually in that location when you look (C\Program Files?)
If you delete the shortcut icon you have on your desktop, and then right-click on CCleaner.exe in Program files and select send to desktop(create desktop)
Does eveything work then?
try @hazelnut recommendation and if not working,try this
change CCleaner.exe to something else like Cleaner.exe , just remove the first C
then try run it again
