Hey,
I added several Auto-Fill Settings (Adress, Email, Name, City etc ...) to Google Chrome, and after i use ccleaner all the Auto-Fill Settings are gone / deleted. Can someone help me?
Thx
Hey,
Thx
Open the Custom Clean, not the Easy Clean, go to the 'Applications' tab and under 'Chrome' untick the boxes for 'Saved passwords' and 'Saved form information'.
CCleaner should then respect those settings in both Easy Clean and Custom Clean and leave the passwords/forms alone.
(If you find that Easy Clean is still removing them then simply use Custom Clean instead).
hehe, thank you. ♥
