ccleaner deletes itunes library...yes it really does,under certain...
I agree with Nergal here. Either that, or if iTunes is being installed differently (somehow) than it normally should be. I've also tried breaking my iTunes install via standard ccleaner install. No luck until I start adding in pathways and directories and files to be killed.
I suggest the next step is to see logs of files and registry settings that are getting changed. Clearly my first suspect of iTunes Library.itl was not the issue, and I don't feel like making any more guesses. Let's see some logs.
I found this little utility, if you're so inclined to get into looking at system changes, -- http://regshot.sourceforge.net/ -- It's basically a before and after snapshot/spy thing. It looks to see what changes have occurred to registry and filesystem. It's 100% freeware and doesn't require an install. It doesn't make changes to you computer.
From the ReadMe.txt:
Readme file of Regshot 1.9.0 (2013-02-02)
Introduction:
Regshot is a small, free and open-source registry compare utility that allows you to quickly
take a snapshot of your registry and then compare it with a second one - done after doing
system changes or installing a new software product. The changes report can be produced in
text or HTML format and contains a list of all modifications that have taken place between
the two snapshots. In addition, you can also specify folders (with subfolders) to be
scanned for changes as well.
I ran it and took a baseline snapshot.
Then I ran CCleaner and had it delete 1 registry key for demo here.
I also deleted a directory containing several files for a Spaceflight Simulator application.
Then I took the 2nd snapshot. And here is the output showing changes to the system. This is displayed when you hit the compare button. Using a tool like this will help you narrow down the file or registry entry causing the problem.
Created with Regshot 1.9.0 x86 Unicode
Comments:
Datetime: 2013/4/19 18:56:08 , 2013/4/19 18:56:36
Computer: XXXXXXXXXXX , XXXXXXXXXXX
Username: XXXXXXXXXXX , XXXXXXXXXXX
Keys deleted: 1
HKLM\SOFTWARE\Classes\.dgr
Values deleted: 1
HKLM\SOFTWARE\Classes\.dgr\: "Viewer"
Files deleted: 6
C:\Program Files\1_Orbiter_2010\Heightmaps\earth-lv11-425-97-5-4.hei
C:\Program Files\1_Orbiter_2010\Heightmaps\earth-lv13-429-340-9-8.hei
C:\Program Files\1_Orbiter_2010\Heightmaps\earth-lv8.hei
C:\Program Files\1_Orbiter_2010\Heightmaps\flat.bmp
C:\Program Files\1_Orbiter_2010\Heightmaps\mars-lv8.hei
C:\Program Files\1_Orbiter_2010\Heightmaps\moon-lv8.hei
Folders deleted: 3
C:\Program Files\1_Orbiter_2010\Heightmaps\nlsbuf
C:\Program Files\1_Orbiter_2010\Heightmaps\srtmbuf
Total changes: 11
But did you use (Duplicate) File Finder, Winapp2.ini-file or Registry cleaner section?
Haven't used any of the above and haven't changed any settings from the default.I have been using cc for a long time and never had a problem till now, if i get a chance i will revert to a previous version and test again.
Problem only started after upgrading from ver.3.28.1913 to 4.00.4064 at end of March
