I really love this cleaner, except for one thing...
I have Roadrunner set as my homepage, and my login info, local weather info, and RR settings are deleted whenever I use CCleaner. This still happens even though I went to OPTIONS, then under options clicked COOKIES, and placed the two RR related cookies into the SAVE COOKIES column on the right. Please help. Thank you.
Welcome to the CC Forum!
I would simply uncheck the cookies cleaning option of your browser for a while. Make sure that you do everything you usually do, then after a few days (or a few hours) go back into Options | Cookies, and see if there are additional cookies for RR.
After I unchecked Macromedia Flash Player, which Roadrunner usess, it seems ok now... your suggestion was going to be my next step. Thanks for your help.
