I use a premium account to remotely access my clients computers in various locations both in the UK and abroad. However, when I run the CCleaner Health Check it shuts down the remote sessions, and it is necessary to keep loggin back into the remote client.
I have only noticed this since version 6.11was created and the problem has continued into 6.12.
I'd be interested to know what has changed within the software upgrades since version 6.10 to cause this annoying issue to occur.
There have been a few issues with the cleaning of teamviewer and some changes made in 6.11 and 6.12.
From what you describe though yours sounds like something different - the cleaning of the browser Session which Health Check does as standard.
Use Custom Clean instead of Health Check and untick "Session" for the browser(s) you use for Teamviewer.
That should then leave the browser sessions alone and prevent you being logged out from them.
Set Custom Clean to be the default that you are shown: Options>Settings>CCleaner home screen.
Note that if you do run Health Check then it will always clear the browser sessions, you can't customise that which is why you have to use Custom Clean instead.
Thank you for your advice, but even when using the custom clean with sessions for all browser entries unticked, the remote client still goes offline during the scanning process.
I too have noticed ever since CCleaner 6.11 and on, that my Teamviewer host has issues staying connected with my client's that run CCleaner. As soon as I remotely launch CCleaner on my client's systems, I lose access to their system. Even disconnecting and re-connecting through Teamviewer, the client screen is frozen on my end. I have to contact them and them exit CCleaner.
I use Teamviewer v15.40.8. I tried using earlier versions of Teamviewer, but that's not an option if the client is using a newer version than the host (me).
Downgrading to older versions of CCleaner like 6.10 or earlier appears to work with Teamviewer.
the same as described above.... When I open connections with Teamviewer, lets say to 5PC, once CCleaner run, all PCs are immediately disconnected. It is very annoying, and from CCleaner version about a month ago. Please remove this bug ASAP
