I'm using CCleaner V3.16.1666 (64 bit), I'm using Windows 7 X64 and Google Chrome version 18.0.1025.108. Every time I run CCleaner then open my Google Chrome browser I receive a message that something is trying to take over my search on my browser, see this screenshot for the message http://screencast.com/t/hHCc8Xxvy but it is a false indication. CCleaner seems to be wiping out something in Chrome to cause this message, is anyone else experiencing this & is there a possible solution?
Chrome saves search engine data (alternate search engines, default search engines) in an SQLite formatted file (Found at
(WINDOWS XP) C:\Documents and Settings\<username>\Local Settings\Application Data\Google\Chrome\User Data\Default\Web Data (WINDOWS XP)
Vista/7C:\Users\<username>\AppData\Local\Google\Chrome\User Data\Default\Web Data Vista/7
NOTE: THESE FILES ARE HIDDEN. YOU MUST SHOW HIDDEN FILES AND FOLDERS
If you look here you see that in the newest version of CCleaner (3.16.1666) the team "improved google chrome history cleaning". They must have included the file located at
Vista/7 C:\Users\<username>\AppData\Local\Google\Chrome\User Data\Default\Web Data Vista/7
WORKAROUND HERE
1. open CCleaner.
2. Go to options.
3. Go to Exclude.
4. Add--> File:
To CCleaner Dev's: If you could, in the next release, please remove that file from the list of things that gets deleted that would be great.
