CCleaner blocks office programs as Outlook and Word. When I look in Taskmanager I see series of “CCleaner reactivator”. When I remove thisthey srtill come back when I want to start Word. Only removing Ccleaner solves the problem.
Anyone a better solution?
Are you using the Performance Optimiser in CCleaner and it has put those programs to sleep?
I had a similar Issue with LibreOffice Calc & Word suddenly not working and found what must have been hundreds of CCleaner Reactivator process’s running. After re-installing Libreoffice found Programs worked through Base Icon, but not programs directly. Finally found problem was a Previous Version of Libreoffice was Paused. Removing it from Performance Optimiser fixed the issue.
