CCleaner behaviour
Did it on a clean install too.
http://forum.CCleaner.com/index.php?showto…indpost&p=10969
WTF?
If you install the VB6 SP6 runtime like already suggested it may actually fix the problem. And like already stated many programs require it, it's a Microsoft distribution, if CCleaner isn't working because of it you'll eventually run into some other program(s) that require it.
OK. Just this once ;) . I installed the VB6 update, and the problem is solved - for me at least. However, this does mean that the needed files distributed with CCleaner are failing to install / override outdated versions (?).
Thanks.
Thanks.
No, it just means that your Windows didn't have some updated system files required for programs.
i can not get it to install properly can someone help me
That's what we're here for - to help you. But we're not going to pull teeth. *You* tell *us* what's wrong. This is like wasting time by asking "Can I ask a question?" when clearly that was a question itself. I suggest you start a new thread about your concern.
In the new thread, give us more information. Tell us first that you're not renaming the download to 'CCleaner.exe', because this will not allow you to install CCleaner. You may want to browse and search the forums a little longer to make sure that your problem has not already been addressed (like the renaming to CCleaner.exe that's been asked a thousand times)
