Asked and anwered a billion times.
Read my signature as to why I think this is a horrible idea
You not currently got a sig
uh yes yes I do
but I will quote it for you (perhaps your forum settings or post rating forbids signature views)
ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTIONJust because something comes up on the REGCleaner section DOES NOT mean that you SHOULD remove it.
IF USING THE REGISTRY CLEANER ALWAYS BACKUP THE ENTRY YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T, AND DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF.
EDIT: HAHA I didn't even realize that it was ident who said that, I thought it was the OP Ident, by the way your sig needs another o, or is it meant to say as it does "bring item a" to "item b" http://www.wsu.edu/~brians/errors/to.html
