Just a quick question. Everytime I download a new version of CCleaner, the next time I start up my computer, the Yahoo Toolbar is on it. Is there some relationship between Yahoo and CCleaner? It is no problem, I just uninstall it, but wondering.....
Yes builds off sites like filehippo, fileforum, softpedia, ect do have the yahoo toolbar installed.
If you read the prompts during instalation you could see that all you have to do is uncheck a box and it will not install it. ![;)]()
You can also find builds without the toolbar here:
http://www.CCleaner.com/download/downloadpage.aspx?1
Thanks. My problem is that I usually blithely go along, not reading the fine print, just next, next, etc. I will be more careful next time. Well, ..... ![:P]()
