I have both Norton 360 / Life Lock and CCleaner. There seems to be a conflict or interaction between Norton and CCleaner
Safe Email is prevented from functioning with comcast.net email (Yes comcast mail security is set up as directed by Norton and Comcast for compatibility.
Norton is working in it as they reached Level 3 during my latest tech support. I did find some info on the net about the conflict due to the functions of the software and some suggestions for fix.
I had norton assistants Level 3 trying to solve the issue with Norton Safe Email not connecting to comcast. Norton agent has me remove ccleaner and told me that it is interacting with the registry.nown conflicts.
Most issues arise from aggressive registry cleaning, not from Norton. CCleaner’s registry cleaner can cause problems if used without caution.
Like
Dislike
Preventing CCleaner from Interacting with Norton Safe Email / Norton 360
You can stop CCleaner from touching Norton Safe Email and Norton 360 by excluding their registry keys, file paths, and processes in CCleaner’s “Exclusions” settings, and by disabling CCleaner’s “Run after reboot” for Norton’s services.
Why the conflict happens
CCleaner’s registry and file cleaners can delete or modify entries that Norton Safe Email and Norton 360 rely on to function — for example, registry keys for email account settings, service entries, or file locations. This can cause Norton’s email scanning to stop working or trigger errors CCleaner Community Forums+1.
