CCleaner Active Monitoring - what exactly does it do?
Usually I use the portable versions, but decided to install Ccleaner and Defraggler.
What exactly is CC it looking for when 'active monitoring'?
Thanks.
monitoring is explained here; http://www.piriform.com/docs/ccleaner/ccleaner-settings/changing-monitoring-settings-ccleaner-professional
with the non-Pro builds, it's function is limited.
OK, thanks.
