CCleaner 7 vs 6 - I ran 7 then reinstalled 6 and 6 found 1.34Gb of additional junk to delete..
What else needs to be said?
Whilst not commenting on the differences between v6 and v7 - you should bear in mind a couple of other things:
Firstly reinstalling 6 will have created junk files. (And if you had uninstalled 7so would that).
Secondly that just runing v6 twice in a row will also find things to clear again.
See this for the reasons why that happens:
I’ve been a computer expert for over 40 years, and a Windows specialist for 20 of them.
I can assure you that reinstalling CC 6 and then performing another clean could not possibly - as you well know - generate an additional gigabyte of files to clean. Particularly since I reinstalled 6 from a stored installer not needing to open a web browser.
Try again, friend.
