CCleaner 64 bit error
In Windows 7 64 Bit, CCleaner 3.02.1343 fails to add files when dragged onto it through the includes. I suspect that excludes fails also, although I haven't tested it yet.
I believe this does work in Windows 7 32 Bit, & I know it works in Windows XP 32 Bit, so I believe this is just a 64 bit problem.
I ran the regular CCleaner installer from Piriform on a new 7 setup straight from walmart.
*Additional info:
I tried the add a file, then navigated to the icon I wanted it to delete off the desktop, but instead of adding the icon, it added the folder that the icon referenced in the program files folder instead (which I promptly removed!).
This this please! I'd hate to know how many people tried to add a shortcut, only to remove a folder of files instead!
Thanks!
