Lately, when I do a Custom Clean to purge alll temp cache on my Windows 11 Pro workstation it appears that once the Clipboard is reach, CCleaner will hang and no longer progress to the next step. It used to take 8 to 12 seconds tops to clean everything. Now it is indefinite.
Screen Shot - postimg.cc/p55twV5b
Anyone has encountered this issue as well?
So far the only way to make it work is to re-start Windows…
I am using a Win 11 pro machine and clipboard cleans for me.
When you clean the clipboard from within Windows does it hang as well or does it complete?
What security do you use?
I asked what happens with clipboard cleaning if you DON’T use CCleaner and clean the clipboard from within Windows.
Windows Settings…System…Clipboard (listed down on the left.)
I have the same issue, even when I clean the clipboard in Windows. The clipboard cache is empty, but CCleanr tries to clean it. Latest version CCleaner and latest version of Windows 24H2. Before the update, it worked fine.
