CCleaner 1.28 problem?
After running 1.28 my system behaves strange. I choose to clean all applications and issues.
When I restarted, I did not get assigned DHCP IP address as I normally do, well atleast not immediately.
And when I opened "Task Manager" then all services and programs had an empty "User Name" field.
I waited a minute or so, and then all services and programs had got the username they are supposed to have and I got an IP address too.
Anyone else know about this problem or got same or similiar problem?
I actually had that problem with v1.27. I haven't experienced that problem with 1.28 yet, but I'll let you know if I do.
EDIT: The DHCP problem
i've had the first problem where the thingy didn't give me an IP address. i went to bed, restarted the comp, and then it worked. i think that it happened with 1.28 too.
I had an error 718 message when I installed 1.28.
I'm not sure but I think it's a dial-up error- I'm on broadband. After another reconnection attempt, it was okay.
Can this problem really be related to CCleaner? I can't figure out how CCleaner could interefere with our DHCP addresses.
I guess that I'm questioning whether or not CCleaner is the problem. I might be, but I think that something else could be going on too. DHCP problems are fairly common.
I don't want to assume that CCleaner is the cause without obtaining some sort of proof. :P
