Hello,
after having installed and used the CCleaner, all rubish and partly removed files have been cleaned up. Only one error message is still remaining.
At startup of PC with Windows XP, the P2esocks_1019.dll is required and it cannot be found.
How can this be solved?
thanks for the help.
oli
22 August 2005 21:20
2
if nothing else works u can download the dll. just goggling it will work then put it where it needs to go wherever that may be
Please ignore the advice from oli.
It looks as though you have a remnant of some spyware on your system.
Please go to the link below:
http://downloads.locias.com/cleaning.html
Download and run any of the programs that you don't already have, following the instructions on that page.
Then post a HijackThis log here.
oli
23 August 2005 09:17
4
as i sed if nothing else works
but still im wrong, this should only be done if the required dll is making it so the comp cannot load windows
Let me make myself clear on what I think is happening.
It is not that a .dll needs replacing because it is being looked for at startup.
It is more a case of stopping the startup entry that is looking for the .dll.
The .dll is possibly part of the spyware that was removed, whereas the startup entry was not.
All would hopefully be revealed in a HJT log.
oli
23 August 2005 11:21
6
i sed what i sed cos on my old comp it would not load windows cos it required a dll, that was a b*****d to fix seeing that i did not understand the command prompt
