my problem is, even after x-ing my cccleaner: when i shut down laptop, it says that cccleaner is still running and that i have to close the program. same trouble? how do proper close the program. just x seems not be enough for my computer. can somebody give me a tip? o.l.i.
Hello olivierlabusse,
Welcome to the forums !!!
It is possible to load more than 1 copy of CCleaner.
Use Ctrl+Alt+Delete to view Task Manager and see how many copies when start and when you exit CCleaner.
Also make sure the option at Options > Advanced > Hide warning messages is unchecked.
http://www.ccleanerbeginnersguide.com/
CCleaner Beginner's Guide.com Bookmark and save to Favorites
Good luck,
davey
