Cc7 does not start correcrly
cc7 starts sometimes correct, but often not
CC7 Doesn’t work for me either. The only options displayed are cloud drive cleaner or disk analyzer. I also had to find the license key coz it didn’t recognise me either. I want the previous version. CC7 full of bugs.
@empoknor321 It sounds like you may have a faulty install. If you go to Windows Settings > Apps and click CCleaner 7 it should show you options to Repair or to Uninstall.
@jane1 see above about a possible faulty install.
But you probably want this, follow the instructions carefully.
Hi @jane1,
The CCleaner 7 service is not running. Please follow the instructions below to resolve the issue.
To fix this issue, you need to restart the CCleaner 7 service. To restart the service, follow the steps below:
1. Press the Windows + R keys on your desktop.
2.Type in the following text and then press Enter.
services.msc
3. If you see a prompt, click Yes.
4. In the Services window, right-click CCleaner 7 and click Properties.
5. In the Properties window, under General tab, next to Startup Type, from the drop-down list select Automatic.
6. Under Service Status, click Start.
7. Click Apply and then click OK.
