Hello,
if I use CC 2.09 anf FF 3.0 Final CC 2.09 doesn't seem to clean FF3 Cache even if I checkmark it.
it shows the message FF?/Mozilla cache cleaning skipped.
is this a bug?
Hello,
is this a bug?
Hello,
is this a bug?
Hi klumy,
Are you positive the FF browser was closed at the time?
If not it probably skipped the cleaning.
davey
I see
but in earlier versions it was possible to clean the cache even if FF2 was open.
Has this been changed since FF 3.0?
I seebut in earlier versions it was possible to clean the cache even if FF2 was open.
No, it was never able to clean while FF was open.
I think the newer CCleaner tells you this. Where prior versions did not.Many users were not closing the browsers and complaining that the CCleaner was not working right when it actually was.All users are advised to close all programs.Run CCleaner by itself then start other programs.Strange things may occur otherwise.The same principle applies to all maintenance programs.
I know there are some users that say "Well I never have.I have no problems".The only thing they lack is sufficient experience and/or knowledge.
davey
