CC shows applications not on PC
Under Ccleaner 3.03 the following show under applications:
MS Office Picture Manager
MS Search Helper Extension
Problem is I don't seem to have these applications on my PC. The only Office product I have is Word XP which doesn't even support Picture Manager! I don't have any Office Viewer programs any longer.
How can I remove Picture Manager and Search Helper Extension from Ccleaner Applications?
I also don't have MS Search Helper Extension installed.
Solution: Untick the box
You can verify you don't have it installed by looking in:
?:\Program Files\Microsoft\Search Enhancement Pack\Search Helper
As for MS Office Picture Manager it detects this key, which if you have Office installed will be there:
HKCU\Software\Microsoft\Office
