CC does analysis but hangs on the cleaning function
I have used CC for years, all good. I have the latest free version installed on two laptops.
One works fine.
The other does the analysis but then hangs at 2% of the Cleaning function.
I noted, however, when I went to cancel, the program apparently went into reverse mode, as if it had completed some cleaning but not all.
Is there anything about my individual LAPTOP config that would inhibit CC completing clean task, under both Windows, and on Other apps tabs. It did the Registry clean OK.
Paul
Please run ccleaner in debug mode (see sticky at top of ccleaner bug reporting board) on the laptop showing the error and attach the log to this thread.
