CC Cleaner Tools Problem
Having problem with CC Cleaner when it click Tool tab it opens normally with Uninstall populated correctly,but when i click either Startup,System Restore or Drive Wiper it does not populate .I also have the same issue with the Add or Remove in the Windows Control Panel not populating also. If i leave either of these open they will eventually populate after 5 to 10 minutes . I've defragged,disk clean up,SFC /scannow ,run Super Antispyware,Comodo and many other . Any Ideas ? Running XP Pro SP-3
What version of CCleaner ?
Have you always had this problem,
or is it a new issue, and if so have you run the registry cleaner (QUESTION - NOT A SUGGESTION) ?
Latest version v3.06.1433 ,have uninstalled and reloaded .Not sure if did this with previous one ,will uninstall and try earlier one . Run registry cleaner frequently . Did not do this in past and not sure about control panel ,i use the CC one normally.Will update after trying other version,Thanks !!
Just tried v3.05.1409 and same problem !
I suggest you download the Portable version and unzip somewhere other than your existing CCleaner version.
If this also fails to populate as required then Windows is not giving CCleaner the information.
If however it does populate then perhaps some registry key/value is stuck and having a bad effect on the installed version.
I doubt that I will be able to help you fix the cause,
but this test might be useful.
I also have the same issue with the Add or Remove in the Windows Control Panel not populating also. If i leave either of these open they will eventually populate after 5 to 10 minutes.
Possibly this is a pc, not a CC problem. Could you open Task manager/Processes, and with this window on top open CC Drive Wiper or other application giving you the slow-down. Then try to see what, if anything, is hammering your system.
