CC Cleaner on 4 users
On my WIN 7 Ultimate I have :
Admin User
3 More users.
The CC Cleaner is different on each user ( Ver,SETUP etc ...)
How can I use one CC Cleaner for all the users with the same setup / configuration ?
Thanks.
I don't know how you can have different versions from one computer when CCleaner is installed to one directory and previous versions are overwritten. Maybe your users are using the portable version?
Anyway, install CCleaner and during the setup process enable the create shortcuts option. That way previous shortcuts on the Desktop and Start Menu are overwritten to give access to the latest version.
As for configuration I'm not sure if you can have one global configuration for each user. Maybe CCleaner Network Edition has the answer.
