Have you read and understood and applied the solution that appears in the first two lines of my post #9 ?
If not then please try it and advise whether that works for you.
I have 64 bit Windows 7 + SP1
but I have no such file in any temporary location
I too have CbsProvider.dll
BUT THEY are held in a sensible place, such as
C:\Winsxs\
and with some sort of magic reparse points they also appear to be at :-
C:\Windows\System32\Dism\
744 KB (762,368 bytes)
Created 21 November 2010, 03:24:22
Modified 21 November 2010, 03:24:22
Accessed 12 April 2011, 09:32:08
and
C:\Windows\SysWOW64\Dism\
528 KB (541,184 bytes)
Created 21 November 2010, 03:23:48
Modified 21 November 2010, 03:23:48
Accessed 21 November 2010, 03:23:48
It is obvious that the above files were created by Microsoft as system files in 2010,
and only the 64 bit variant was accessed on the date when Windows was installed on my SSD.
Therefore the file you are concerned with is not a Windows file, it is an A.V. vendor file placed in a stupid place in the foolish hope that malware will not know where to find it.
I am pleased to say that I use protection which protects its essential files so that CCleaner is not able to damage its operation.
What size is the file you are concerned about, and what are the date stamps shown in its properties ?
This topic was started by a Bitdefender user.
It is unfortunate for the user that when the user makes legitimate use of the right to purge his Temporary files then Bitdefender kills the computer
This right has existed since there was DOS - many years before Windows.
If Bitdefender cannot protect its files from the user then it has no hope when malware comes knocking at the door.
