I cannot post in this forum, everytime I try I get "CCleaner has encountered a problem and needs to close". The weird thing is, its just on this forum. I am on another computer posting this topic. Anyone have any idea how to correct this problem? Any help will be appricated.
Are you able to run the CCleaner program okay Freestyle?
Do you have any other problems with your computer you have noticed lately?
Hi Hazelnut, I can run CCleaner with no problems. I did have a problem with the "Secure file deletion " awhile back, it would give me the same error message as above^ but would work fine in the "Normal file deletion" so I reinstalled CCleaner and corrected that problem.
No other problems with computer that I can notice, just when I try posting a message that it gives me the error as above. I can read all the post with no problems, its just CCleaner forum that I cant post in. I have no problem with anyother forums I post to, I know its very weird!
There was a virus a while ago that wouldn't let anyone use CCleaner or even type it.
Are all your scans etc up to date?
Which browser do you use? If possible could you try another one?
I have Internet explorer and FireFox, it seems i can post with FireFox but not Explorer,guess its something with Internet Explorer. Do you have any idea what it could be with Explorer?
Also everything seems to be updated.
Might be worth posting a HijackThis log in the relevant section of the forum just to make sure theres nothing malicious causing it.
HijackThis forum section: http://forum.piriform.com/index.php?showforum=12
Instructions on how to post a log here: http://forum.piriform.com/index.php?showtopic=1720
As Hazel said there were users having strange problems like this a while back caused by a particular virus. It may have nothing to do with that virus but probably worth posting a log just in case.
