Can not access subscription info
I have a valid subscription, I have had for many years. It is set up to auto renew. I attempted to access the subscription info to see what I’m paying for and received a message I should “contact support”. However there is no contact for support leaving me chasing my tail. How can I fix it or contact support ?
If you want to manage and/or cancel your subscription then there is a webpage to use:** Subscription Management
If you need to look up your Cleverbridge reference then see: Cleverbridge Lookup.
If you can’t use those, (eg can no longer access your registered email), or for anything else account/billing related, including refunds, then you will need to contact support.
To start the support process fill in this form: Support Contact Form.
Once you click ‘Next’ to submit the form you will be given a support ticket/ID number onscreen, with a summary of your request.
(If you don’t see the ‘Next’ button at the bottom left of the form then refresh the page before typing anything in).
The 'Live Chart dialogue should open automatically with a message from the AI Chatbot - if it doesn’t open itself then there is a ‘Start Chat’ button.
If the Chatbot can’t help then you will be passed to a real person.
IMPORTANT- Don’t just fill in the form and leave - If you do not engage with the chat then you will not get any reply.
The first link is the one is the one that fails and tells me to “contact support”. The second link tells me I aill get an email but it never arrives. The third link provides the email address and license key that I already have and use.
Then as I said above you will need to use the Support Contact Form and live chat at the 4th link.
Hi @rszanti,
I have sent you a DM for more details on your CCleaner licence so I can advise you further on this issue.
